Fault code 01217 help needed.
Upper limit exceeded, o/s front drivers side airbag igniter. Anyone had this before and how did you get it fixed. Any help appreciated.
Possibly the wiring on the igniter or somewhere between could be jammed or broken..
also check the plug/conectors under the seat in case they have been pulled out or damaged.
Edited by AkisVH
Will check thanks.
