Fuel Filter Housing
Hi, just had my 09 LE CR serviced and after about 100 miles the fuel filter housing is leaking from around the edge, it's not in great shape with rust anyway so was going to replace it with a good 2nd hand one, does anyone know the part number as Google throws up loads of different variants?
Look at the side there is a label. There are lots of versions last letter is different therefore insert filter part is also based on that.
Ah, Ok cheers will check tomorrow.
Edited by T2000
Found the number 3C0127400C, I can get a new 3C0127400D would that be suitable is it just a revision?
