Trim removal
I need a little bit of assistance when it comes to removing the plastic covers which go over the top mounts for the shocks. i'm wondering how i can remove them.
This is the piece for reference.
Does this help?
If its anything like a Fabia, you might need to remove quite a few clips, screws etc.
Have a look at this link
https://workshop-manuals.com/volkswagen/up/body/general_body_repairs_interior/trim_noise_insulation/load_compartment_trims/removing_and_installing_load_compartment_side_trim/
Will be the same for a Citigo.
The website is a bit tricky to navigate. The highlited 'Chapters' in red that are often referred to in the instructions are dead end links.
You need to find the main topic / area that you want on the left hand side of the page and then click through every subsequent page to the one you want using the Prev/ Next page buttons near the top right hand side. Hope that makes sense!
You will need to do this to find out how to remove the C trim and that depends upon whether you have a 2 or 4door car.
Good luck.
