Dipped headlighs not working
Hi guys, bought a second hand 58 Fabia. The headlights stopped working all of a sudden. Bulbs are fine and seem to have been replaced recently. What else could be the problem.
Cheers in advance
Michael
Checked the fuse?
Yes mate fuses seem fine
If not fuses and bulbs, might be the actual switch. They do go wrong occasionally. You say dipped... Are the main beams working ok, from the switch or just if you flash them? Do you have projector or reflector headlights? If reflector, you may have twin filament bulbs that could have just one filament blown. If projector and the flash works but not main beam, again, I would suspect the switch.
