Silly Steering Question
Hoping i can get a definitive answer, but basically there was a problem with my order - a Sportline Plus 280 (some option not available anymore) - so decided to add the heated steering wheel (with DSG paddels) with the refunded missing bits.
It was a bit of a rushed decision, and now i'm worried that it's not going to be the same as the wheel we test drove.
Does anybody know for certain if it will still be flat bottomed and exactly like the standard sportline plus wheel, but with heating element inside - or do i need to get them to remove it ASAP?
It probably sounds silly, but i'd rather be with a wheel that we tested and "liked" than a heated but unknown unit.
(The configurator shows flat bottomed in the option picture, but it's not known for it accuracy).... To be honest id' love the alcantara one but that's not an option so ignore that :-P
It should be a flat bottom multi-function steering wheel as per other Sportlines.
It’s in the brochure IIRC. If in doubt then use the online chat tool with Škoda customer services.
Good idea :-) thank you. However, based on previous interaction, i won't hold my breath.... :D
