Octavia mk1 vrs estate boot spoiler
How do i remove the boot spoiler off my Mk1 octavia vrs  estate?
Mine seems to be doing a pretty good job of removing itself. I believe the correct way is to use some fishing line to slice through the sealant that it is stuck on with. Remove the upper trim panel, disconnect the hi level brake light wiring and squeeze the 2 white clips, and it should lift off. Its the next job on my list.
Dental floss will do the job if no fishing line is available.
I find peppermint flavour works well ;)
