FuseBox
Have a 2017 Model Skoda Superb and trying to locate the fusebox and gain access. Anyone know where it is and how hard/easy to access ?
Behind glove box, there is a tab u need to take off to drop glove box down.
Check this thread there is a screenshot of manual thay gizmo has posted which shows how the glove box is removed
Yes it is the same. Mine is a 67 plate and its in same place.
That's great thanks - Though looks a little complicated as not a mechanic, attempting to fit a dashcam !
At first it is a bit fiddly to pull the support arm out of its engagement with the pawl on the glovebox but it is well explained in the manual. Once you done it you can see how easy it actually is for the next time.
Thanks Terry
Fairly easy once u get to the fuse box. I have a front and rear camera in mine.  Let us know how u get on!
Thanks Adrian - Will give it a shot
I pulled the end panel off at side of dash to feed the wire through to fuse box and also used a screw there for an earth
Is it then similar to this Video ?
<iframe width="914" height="514" src="https://www.youtube.com/embed/bUIHTMkl7M0?ecver=1" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
That didn't work in embed code so
Yes its exactly how i did it and i also used that same bolt as an earth
Great that's good to hear.
