Oil service warning
Is it possible to switch of/reset on superb 111
Presume you have had the required service carried out by an indy who does not have the software to reset the dash.
On other brands I have owned its been possible using a combination of buttons on stalks/dash. The pdf manual says "We recommend that you do not reset the service interval display yourself. Incorrectly setting the service interval display could cause problems to the vehicle." which suggests it is possible but it gives no instructions.
No idea where you are but some member may be able to assist but other than that it looks like a dealer visit and £££'s.
Try this it worked for me https://www.briskoda.net/forums/topic/439061-oil-service-reset/ . If you don't have KESSY just use the key as normal.
