Tandem pump
Has anyone ever had a leaking tandem fuel pump were as oil is coming off it and covering the side of the engine.
If its leaking from between the pump and the head it will need new seals. Some use 'O' rings and some use some sort of gasket. (They once ordered me the gasket when I wanted the 'O' rings at the dealer)
Its not a big job
Cheers for the reply thats what am trying to distinguish do a need gasket and seals or just one or the other.
Depends on what make of pump it is, there are two options.
And yeah, it is pretty common.
Thanks for that
Don't no which 1 it is all a do no is the engine is a BLS so bout sure thanks.
Send an email via the parts section on here and they should be able to find out for you.
