4x4 Service advice
My 2002 4x4 is due for its second variable service. Its done 30k. I've been quoted various prices from
Hi Mate
If it is on variable I would say that I would do the 40k
As the parts required on a 40k is running really at its max.
Then the car will not be requiring another service for 20k ish or 2 years.
It is my opinion that them parts would be pushing it to go on to about 50k miles.
There is also the Haldex that requires a service at 40k too.
So check to see if the dealers are doing that service at the same time.
Brake fluid is every 2 years too.
Sarah
As your car is out of Warranty try people like Jabba, they also service cars as well as tune them, their labour rates are probably less than a main dealer & they are also probably better at the job anyway. They will also use decent oils & fluids, not just the min spec reqd by VAG
£350 seems a lot for a 40k service as well...
My 4x4 recently had the 40k including Haldex oil change etc and it was just over £200 at Panda in Swansea.
I thought
That is very cheap if it includes LongLife oil, plugs, Haldex filter, and brake fluid change as well.
Hi
You will find as DGW said.
The oil is
