BCM Access?
I'm hoping for some advice following a fruitless search of the internet and forum and review of the workshop manuals.
I'm trying to access the BCM - I have found an image of where it is located, but how is it accessed (and what does it look like)?
I can see the fuse board behind the glove box - is the BCM the box to the left of this, and if so how do I access / remove it (the BCM, not the glovebox)?
Edited by Wangarai
its a large socket with a white lever lock. its a PITA to get at if you have large hands, you can work it out as i have.
its in the top left with white tape wrapped around it in this image.
to remove it push up and to the left on the lever and pull the bcm to the left and down into the footwell
Edited by JohnnyType2
2 minutes ago, JohnnyType2 said:
its a large socket with a white level lock. its a PITA to get at if you have large hands, you can work it out as i have.
Great - thanks - exactly what I'm looking for.
So, I only need to remove the glove box. Does it drop out to the footwell when the lever is released?
glove box and side cover on the dash will make it easier to get the glove box out. When the lever is released you will need to pull it down into the footwell, its stiff and will need some force to pull it out and down.
