ENGINE NOISE
SOUNDS LIKE A BLOWN EXHAUST BUT NO LEAKS FOUND ALSO SMOKE FROM EXHAUST EVERY NOW AND THEN
Is it a recent purchase? Is it a diesel? Has it had its DPF removed?
Is it in warranty?
Edited by xman
NO WAS PURCHASE NEW IN 2015 IT HAS DONE 200,000 MILES BUT THE NOISE ONLY STARTED LAST WEEK  ALSO IT HAS TAPPIT NOISE ITS BEEN A TAXI FOR THREE YEARS
Get a mechanic to look and find where the noise is coming from.
HI XMAN THANKYOU BEEN IN THE GARAGE THEY SAY POSSIBLE INJECTOR OR LOSS OF COMPRESSION NO FAULT CODE SHOWING
Well there you go then.
At 200,000 miles not surprising something is worn or wearing out.
Get a compression check done to check the piston rings/bores and valves are still reasonably healthy. Then get injectors checked out, probably need new seals if they are removed.
Then ask yourself if its worth the expense to refurbish whatever needs to be done or get a replacement engine or sell the car and get something newer.
