15" 5x100 Seat Alloys with Nokian Winter Tyres
I have a set of 15" Seat Alloys that are now surplus to requirements.  I will put up pictures as soon as I can get them out of the shed in the daylight.  The tyres are 195/65/15 and are Nokian WR D3.  All have plenty of tread and no punctures.
Looking for £120 for the set.
Hi trundlenut,
What car did they use to be on? What are the wheel specs? CB, ET..?
10 hours ago, 26DIPP said:
Hi trundlenut,
They are off a mkI Seat Toledo, I used them on a mkI Leon.  I will need to check the offset, but the centre bore is standard VAG, 57mm or whatever it is.  They will fit a mkI Octy, mkIV golf, fabia, polo etc.
I think some more details might help you sell these such as tyre size and how many mm of tread left on the tyres.
I know, they are at the back of the shed and I haven't had chance to extract them yet. The first post has the tyre size. From memory they all have about 6mm tread. I'll put up pictures and full details at the weekend.
Right then.  The wheels are as follows: Seat part no. 1M0 601 025, they are 6J with an offset of 38, 5x100 with normal VAG centre bore.  The tyres are Nokian WR D3 195/65/15 91T, all four tyres have around 6mm of tread, no puncture repairs and no signs of uneven wear.  The come with Seat centre caps which cover the nuts.  Pictures will follow shortly.
Hi, what’s your location? Thanks
I'm near Derby, so quite a long way from you it seems.
Yes you are a bit far away! I would have had these if you were closer!
 Thanks anyway
These have now been sold to a man with a very poor grasp of geography.
  • Gizmo locked this topic
Guest
