Clutch is on the floor and not returning back up unless I pull it up with my hand
My clutch pedal is not returning back up when I push it to the ground it just stays there.
Also my brakes are all seized up too, put my hand brake down and the car is not moving at all.
Please help
Does the Mk1 have a hydrolic clutch, if so check it for clutch fluid.
@V23vrs @towserdog - Yes the vRS has a hydraulic clutch. Start by checking the fluid reservoir (shared between brakes and clutch) and if that's dry look for leaks before topping up.
