High Beam Assist
Hello, I've tried to enable HBA in the Vrs 245, using odbeleven.
All looks ok, icon on the dash when pushing stalk fwd. Except it doesn't work?
Tried a reset and enable again, nowt, just stays on dipped beam all the time.
Anyone give me some pointers please.
Codes used
High Beam Assist
STG09
Security access 31347
Adaptation
FernlichtAssistent
Menusterung Fernlichtassisten -> Present
Menusterung Fernlichassisten werkseinstellung ->Present
Erweiterte Fernlichtassisten -> AFS, FLA, Fernlicht uber AFS
STG A5
Coding
Byte 21 bit 5-7 - High Beam Assist
So you get the icon of the headlight with the A in? It should work fine then. Note it doesn't kick in until a certain speed, have you actually been out at speed on a totally dark road to test?
I followed the guidance in this thread and it works well
Cheers @mumphie
ah, looks like the info I had missed this bit
Controller 4B - Multifunction Module
Coding (using experimental coding values)
-Byte 11, Bit 6 (High Beam Assistance,Enabled)
You may get an error pop up regarding Headlight Range Control. To clear this, go to Controller 4B, Basic Settings.
-Basic Headlamp setting -> Go
-Acknowledge basic setting -> Go
Will try it again later.
Cornering fogs, traffic sign recognition, and hopefully HBA all sorted.
Just need to find the Audi throttle mod next :D
Edited by garpat32
5 hours ago, garpat32 said:
Cheers @mumphie
Throttle mod doesn't work on the 245. At least, I can't get it to work...
Yeh, HBA all works now.
Handy feature, but I'm not sure I'd pay the cost of adding it as an option though.
Cheers.
I need to learn how to use my OBDeleven properly! I would like to activate a few things when my MY19 turns up!
