Help needed re fitting start/stop deactivation module
Hi Folks I have purchase a start/stop deactivation mode  for my 2015 yeti se
https://www.ebay.co.uk/itm/NEW-Start-Stop-Memory-module-with-SERVICE-MODE-Start-Stop-SSA-memory/322352078637?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
I came to fit it today  and amediatly ran into a proble . I managed to carefully pull the switch out of the dash it has four wires going to it
Purple,
Purple white
Brown
Black yellow
The SSA-Memory module wireing instructions are very basic .I need to know which is the signal wire and ACC+ wire  and gnd their simple diagram has the wires coloured
Red =acc + green=signal
black =gnd
HELP PLEASE
Mike
  • Sponsor
All the diagrams I have show five wires, with a grey on pin 3 of the 6 way connector?
Anyway, brown pin 6  - earth/gnd
Black/yellow pin 4  -  ignition 12v
Purple/white pin 5 -  switch output to engine control unit.
The Kufatec module just plugs into the obd to deactivate the stop/start and is removed after
Which has no relevance to the unit the OP has purchased!
Thank you Gentlemen advice much appreciated .
I think I need to get a manual for future use
the emanualonline.com at £20 looks good ??
Thanks again Guys
Very true, I only added the post for anyone wanting to delete the stop/start using a simpler method.
12 hours ago, langers2k said:
I'd use the official ones from here: https://erwin.skoda-auto.cz/erwin/showHome.do
It's a pay per time frame of access but if you have a "print to pdf" function you can keep the info :)
Set aside an hour of time, and so long as you've got a reasonable internet connection, you should be able to grab all Yeti-related infomation in one session :)
Hi Guys
 Just a quick UPdate and Thank you for all your replies.
Well this morning I set too and fitted the Stop/start module and now that I had the wireing colour codes sorted it was a easy fit.
and I must say I am very happy with it .
 I realize there are alternative ways of going about solving this problem the cheapest and easiest is the VDCS route providing you have access to a VDCS unit
another way and about the same cost as the way I did it is a Kufatec unit . But both these methods switch the stop/start feature off completly.
The SSA-Memory module remembers your last setting   and IF you do find yourself in a situation where the stop/start feature would be usefull a press of the button and it is back working Also it has a service feature i.e. press and hold the button for 10 seconds and it switches itself completly off and to all apparent circumstances your vehicle has not been altered in anyway .
It is these last two features that sold it to me ,it is easy to fit and works .
Take Care All
 regards Mike
