anyone with vdcs could help me
hi all . i live near preston lancs. just retro fitted a 3 spoke steering wheel with paddles to my 2010 elegance estate. somewere when a friend has activated the paddles he has deacivated the rear wiper and washer? could anyone help. he admits hes lost..the vdcs he used i have have not seen before and is quite oil.. when we scan code its says rear wiper not installed. i just used it this morning on the way to him. all the othe buttons work great and stalk controls aswell just rear wiper.cheers bernie
Can you post a copy of the auto scan? It would also help if your friend upgraded to the latest version of VCDS as it is free on the Ross-Tech website.
Edited by Liger1956
Bernie came to me with his car and has just left. This is his autoscan. Unfortunately we couldn`t work out why the rear wiper isn't working even though the box was ticked in what we assumed was the relevant section. Bernie might be able to explain it better when he gets home. I didn't originally set up the new steering wheel.
Wednesday,28,November,2018,15:21:15:07794
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 18.9.0.2
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: TMBK**********   License Plate: ******
Mileage: 235650km-146426mi   Repair Order:
Chassis Type: 3T-SK46 (1K0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 36 37 42 44 46 52 55 56 62
          72 77
VIN: TMBK************   Mileage: 235650km-146426miles
Address 01: Engine (CBB)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 QJ    HW: 03L 906 022 GA
   Component: R4 2.0l TDI G000AG  9979
   Revision: 13H04---    Serial number:
   Coding: 0001078
   Shop #: WSC 58017 001 1048576
   VCID: 7DF1B54924EF1CA2BE-8028
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 052 S    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2108
   Revision:    51112    Serial number: 00001005111011
   Coding: 0000020
   Shop #: WSC 33361 790 00999
   VCID: 2447A02DE7C58D6A91-8070
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 863D601609260000610E06EB90210082340000
   VCID: 78FFA45DCBCD398AED-802C
Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
   Part No SW: 3T0 907 044 AS    HW: 3T0 907 044 AS
   Component: Climatronic   H15 0401
   Revision: 00005001
   Coding: 0000000002
   ASAM Dataset: EV_Climatronic A01006
   ROD: EV_ClimaAutoBasis_SK46.rod
   VCID: 0305C3B18A0B6A52C8-8056
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 H    HW: 1K0 937 087 H
   Component: BCM PQ35  H+  103 0575
   Revision: 00103 AE
   Coding: 48010AB8F85BF1C040080080010089E4437100AE736D85605C0140000000
   VCID: 36636A6581590FFA3F-8062
   Subsystem 1 - Part No: 3T2 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 13051  22  0602
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 150510 05  54  0403
   Coding: 0730ED
ÿž
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
3 Faults Found:
00323 - Vehicle Inclination Sensor (G384)
            014 - Defective
             Freeze Frame:
                    Fault Status: 01101110
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 20
                    Mileage: 235614 km
                    Time Indication: 0
                    Date: 2013.04.20
                    Time: 10:02:17
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.85 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01135 - Interior Monitoring Sensors
            014 - Defective
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 20
                    Mileage: 235614 km
                    Time Indication: 0
                    Date: 2013.04.20
                    Time: 10:02:17
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.85 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00907 - Intervention load Management
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 6
                    Fault Frequency: 10
                    Reset counter: 60
                    Mileage: 235616 km
                    Time Indication: 0
                    Date: 2013.04.20
                    Time: 11:00:07
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.90 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 10: Park/Steer Assist (J446)       Labels:. 1Z0-919-475-V1.clb
   Part No SW: 1Z0 919 475 B    HW: 1Z0 919 475
   Component: PARKHILFE 4K  H06 0006
   Revision: --------    Serial number: 66641013402499
   Coding: 100108
   VCID: 408F0CBDD39DB14A95-8014
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 3T0 959 655 B    HW: 3T0 959 655 B
   Component: J234__LDB VW10 HI   1916
   Revision: 19014000    Serial number: 003GRP9QRYA5
   Coding: 0017474
   VCID: 408F0CBD139DB14A95-8014
   Subsystem 1 - Serial number: 6332MTS676071260
   Subsystem 2 - Serial number: 6342MTS625431260
   Subsystem 3 - Serial number: 6351HTS63LB099KR
   Subsystem 4 - Serial number: 6361HTS6F64099KJ
   Subsystem 5 - Serial number: 63727TS66ARG89KR
   Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Component: J0527           056 0111
   Coding: 0001831
   Shop #: WSC 04008 758 999999
   VCID: 76E3AA6501D94FFAFF-8022
   Subsystem 1 - Part No: 3T0 959 537 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO   H07 0012
   Coding: 00000131
   Shop #: WSC 00000
1 Fault Found:
01044 - Control Module Incorrectly Coded
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 3T2 920 941 E    HW: 3T2 920 941 E
   Component: KOMBI         H05 0305
   Coding: 411F00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
   ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
   VCID: 377D67618E53F6F224-8062
Address 19: CAN Gateway        Labels:. 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0233
   Revision:   H16       Serial number: 4540K10511883C
   Coding: EDA1FF06400602009303
   VCID: 69D9F1194067900262-803C
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H05 0305
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB8E158D619B1A6B-803E
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760     HW: 3C8 959 760
   Component: J810                0801
   Revision: 00002000    Serial number: 00000000000000
   Coding: 0000003
   VCID: 72EB96756DB153DAD3-8026
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 3T0 035 680 A    HW: 3T0 035 680 A
   Component: RNS-MID       H06 2724
   Revision: AB001001    Serial number: SKZ6Z7K3139016
   Coding: 040004020004008100
   VCID: 2E5342057909373A77-807A
Address 42: Door Elect, Driver (J386)       Labels:. 7N0-959-793.clb
   Part No SW: 7N0 959 793 A    HW: 7N0 959 793 A
   Component: TSG FA        H03 0200
   Revision:             Serial number: 0000010681854
   Coding: 011D0220DE01121002
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 196    3001
   Revision: 00H17000
   VCID: 31695979A83728C26A-8064
Address 52: Door Elect, Pass. (J387)       Labels:. 7N0-959-792.clb
   Part No SW: 7N0 959 792 A    HW: 7N0 959 792 A
   Component: TSG BF        H03 0200
   Revision:             Serial number: 0000010683920
   VCID: 3F8D0F41AE63CEB2EC-806A
Address 55: Headlight Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0142
   Revision: 00H04000    Serial number:
   Coding: 1377095
   Shop #: WSC 52918 001 1048576
   VCID: 3467506D57251DEA01-8060
   Subsystem 1 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000021
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0004
   Coding: 00000021
1 Fault Found:
02988 - Left-Hand/Right-Hand Traffic Switchover Active
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 20
                    Mileage: 235614 km
                    Time Indication: 0
                    Date: 2013.04.20
                    Time: 09:57:22
             Freeze Frame:
                    Voltage: 11.79 V
                    Speed: 0.0 km/h
                        ABS 1
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-795.clb
   Part No SW: 7N0 959 795     HW: 7N0 959 795
   Component: TSG HL        H02 0200
   Revision:             Serial number: 0000010648082
   Coding: 010C00200001221002
   VCID: 0109C9B998177842DA-8054
Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794     HW: 7N0 959 795
   Component: TSG HR        H02 0200
   Revision:             Serial number: 0000010650704
   VCID: 55A1CDE93C1F24E2D6-8000
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 B    HW: 3C8 035 730 B
   Component: Telefon       011 0723
   Revision: --------    Serial number: 35909603219465
   Coding: 020100000100010000000000
   ASAM Dataset: EV_UHVPremi A02003
   ROD: EV_UHVPremi_A02.rod
   VCID: 224BA63535D1835AE3-8076
2 Faults Found:
9457427 - Left audio channel for speech/telephone
          B104F 13 [009] - Short to GND
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 48
                    Reset counter: 20
                    Mileage: 230175 km
                    Date: 2018.05.29
                    Time: 10:27:49
0022 - Radio
          U1066 00 [008] - No Communication
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 31
                    Mileage: 234036 km
                    Date: 2018.10.04
                    Time: 09:51:25
End-------------------------(Elapsed Time: 04:21)--------------------------
Edited by ashfan
cheers ashfan.your help was greatly appreciated
weird one this according vcds the rear wiper is installed.it works when you select reverse but not on the stalk. as i hadnt save my block code we read ashfans block code off his car for steering control module code. as its the same model as mine exactly inc my old steering wheel
we then put that code in my car and the paddles stopped obviously but the rear wiper still doesnt work. code in my car say  steering  control module incorrect code. even though in effect its the std code. so on the way home wondered could it be a fuse maybe?. not checked yet.is the rear wiper washer on a joint fuse?.
checked fuse 39 wiper all ok checked tailgate for shutting properly ok..
@ashfan - did you check the coding of the steering controller at address 16 as it looks wrong to me.
In the scan above it's 0001831, I'd probably try 0001832.
langers do you mean this
 Coding: 0001831
we grabbed that from ashfans car as i had not made a note of my stock codes foolishly.
code 01044 came up as the only code control module incorrectly coded
000--- intermitent
we  did have 00000131 as a code in there when the paddles worked
and also code 0001134 showed
so as of now with 0001831 we have no paddles but all the switches work. no auto lights on as i think this option was turned off on ashfans car and still no rear wiper or rear washers.
Just to point out, this is a forum and not whatsapp. It's easier to read if you make a single post rather than three one liners. There should be an edit button (not sure if it appears for non freedom members) so you can add to your post for a few minutes.
I don't have a car with the same module installed so I'm basing the advise on this screenshot:
Assuming you're still with ashfan, you should check that matches the coding helper that shows when you attempt to recode the steering module. None of this should effect auto headlights either.
You're going to need to make it much more clear what fault codes are shown and what does/doesn't work with each of the codes you've tried.
Based on the above screenshot, I'd guess at 0001832 to start.
sorry langers .
i think this is way over my head now. i build engines  not really a vcds man. i will contact some specialist and book it in and leave it with them.
i cannot give you the info you require as i dont understand what it is i need to do. not your fault mine
No worries, hopefully @ashfan will see these posts and maybe able to help.
sat and looked at the  image above ..on his system it was the same except the rear wiper option was not there?.
we went numbers
2.1.5.3 no last option
it gave options of pttt on the wiper stalk or not so we pick not,but this option was on the next page afterwards
Edited by rockabilly
No, as I explained to Bernie (rockabilly) my experience of vcds is solely from following instructions on this forum to do certain things to my car such as enabling hill hold, fitting a reversing camera etc. Without instruction I have no idea how to use vcds but I am more than willing to allow anybody to use it if they want.
Bernie, if you want to come back and try 0001832 you're more than welcome
cheers ashfan.. tommorrow i am going back to my mate lol and we will did deeper he says. will update if i get anything sorted.
quick on ashfan do you auto headlights work?. after the install of your code and settings mine dont i wondered if yours have been deactivated?.
Yes my auto lights work fine. I don't leave the switch in the auto position but switch to it when I  know I need lights. I don't need the car to tell me when to turn the lights on, I find it a bit too sensitive sometimes.
