VCDS / OBD11 coding page
  • 1 year later...
I tried some of those and managed only to enable:
1)
SOFT SWITCHING ON AND OFF (FADE-IN / FADE-OUT) OF THE CABIN LIGHTS
1.- Control Unit 09 - Electronic control unit. (31347)
2 - Adaptation
3 - Go to " Suchbeleuchtung_allgemein: "
4- In " KL58 Einschalten mit Rampe: ", change inactive to active.
and more importantly:
2)
DIRECT ACCELERATION - THROTTLE RESPONSE
With this mod, we can change the behavior of the throttle. Option B offers more linear acceleration without sudden deliveries.
Steps:
1 - Module 44 - Power steering.
2 - Adaptation
3 - Select - Driving profile switching
Options:
A - Gradual, time controlled (this is the one that comes standard) We
select option B
B - Directly, controlled by threshold value
We accept and enter the code (19249)
Default throttle response was driving me crazy as it made no sense to me - I like direct throttle response
then I tried following:
3)
TEST OF NEEDLES AND LIGHTS IN CONTACT > thought it would be cool to have this effect when turning the car on :o (don't judge :D)
Go to module 17 , instrument panel
Enter Extended Coding
Access byte mode
In byte 1 , set bit 0
Confirm , code 25327
As soon as I enter code '25327' I get "Engine RPM too high" message in OBDeleven
4)
VOLTAGE LIMIT START STOP DEACTIVATION
IMPORTANT : Deactivation of the S&S through this mod is permanent, as long as the default value is not restored. The mod prevents the system from being activated.
1. Go to Module 19 - Data diagnostic interface .
2. Select Safety Access: 20103
3. Select Adaptation
4. Select Initial Voltage Limit Start / Stop
5. Enter value 12 6. Confirm the changes.
This function is the one that deactivated the Start Stop when the battery is low on charge, so it has a value of 7.6, when this value is raised and in normal conditions, the battery does not activate the Start Stop.
But as soon as I enter "Select Safety Access: 20103" I get a "Engine RPM too high" message in OBDeleven
I am using OBDeleven v0.23.3 on android phone connected to bluetooth OBD module (white one)
Does anyone know how to bypass "Engine RPM too high message" in OBD? If I shut the car off, then OBDeleven loses connection to the module and I am unable to make any changes
Are you saying you have the engine running when carrying out these mods, and not just the ignition on as is normal.
Yes, the engine is running. I cant get ODBeleven to connect to the module when I have just the ignition on (I presume module does not get any power?).
you were right after all, the engine was running but just the ignition was enough
I made following changes without issue:
DEACTIVATE START/STOP - START/STOP icon still lights up on intersectons, but the engine is NOT shutting off
5. Enter value 12.6 (from 7.6 to 12.1 kodiaq)
COMFORT BLINK CYCLE
Select Control unit 09 (Central Electrics)
Security access > Access Code: 31347
Adaptation
Access Control: Komfortblinken Blinkzyklen
Value: 1-5 Value 3 (standard – 3 x blinking)
[Reset “Lights” to factory settings on the radio]
DAY LIGHTS (DRL) ALSO ON EXTERNAL REAR LIGHTS > I don't know why this isn't enabled by default, makes the care more visible during the day (and cooler looking with rear LED light glowing dark red)
1 - Module 09 - Electronic control unit. Code (31347)
2 - Adaptation
3 - Leuchte23SL HLC10
4 - Lichtfunktion D23 - (Change value to Tagfahrlicht )
5 - Dimmwert CD23 - (Change value to 100 )
6 - Dimming direction CD 23 - (Change value to Maximize )
7 - Leuchte24SL HRA65
8 - Lichtfunktion D24 - (Change value to Tagfahrlicht )
9 - Dimmwert CD24 - (Change value to 100)
10 - Dimming direction CD24 - (Change value to Maximize )
ACTIVATE "EYELASHES" (STRIPES) IN "DRL" DAYLIGHT FRONT HEADLIGHTS > minor change but also makes the car stand out more during the day
This mod activates the vertical stripes of the headlights with the Daylight.
Module 09 - Electronic switchboard
Go to Adaptation
Enter Leuchte16BLK SLB35BLK SL KC9
At Lichtfunktion C 16 Change nicht aktiv to Tagfahrlicht
On Dimmwert CD 16 Change 0 to 127
Confirm, code 31347
Enter Leuchte17TFL R BLK SRB3TFL R BLK SR KC3
At Lichtfunktion C 17 Change nicht aktiv to Tagfahrlicht
On Dimmwert CD 17 Change 0 to 127
Confirm, code 31347
