Brakes: Brake Fade Causes And Cures
  • Administrators
The following guide looks at common causes and cures of brake fade.
Pad Fade
Pad fade occurs for several reasons. All friction material (brake pad stuff) has a coefficient of friction curve over temperature. Friction materials have an optimal working temperature where the coefficient of friction is the highest. Sometimes you can use the brakes so hard that you get the temperature over the point of maximum friction to where the coefficient of friction curve starts to decline.
The mechanics of this decline in the coefficient of friction are varied. At a certain temperature, certain elements of the pad can melt or smear causing a lubrication effect, this is the classic glazed pad. Usually the organic binder resin starts to go first, then even the metallic elements of the friction material can start to melt. At really high temperatures the friction material starts to vaporize and the pad can sort of hydroplane on a boundary layer of vaporized metal and friction material which acts like a lubricant. Pad fade is felt as a car that still has a decent, non mushy feeling brake pedal that won
