EPC light on
I was changing my boot bulbs with LEDs then the lights went of now I have EPC on and the car is gutless . Anyone help me
No help :(
You have been a bit vague.
what exactly happened? which lights went off? are they still off? Did you short something out?
bottom line you need a code reader to figure out what has happened
I was putting led bulbs in the boot and all my interior lights went off I then went to go out and the epc light was on and the traction control light is on . This morning I started it and it don't sound well at all
What year, pre FL or FL?
2006 so pre FL. I didn't unplug the battery so must have shorted something out but God knows what
does seem like something has shorted out
Do you reckon I've popped something or something as simple as a reset . I've seen on YouTube ways to turn of the EPC light but would that work
  • Sponsor
Check all your fuses one by one.
So say there was a fuse that's gone would that make the car run so bad ??
  • Sponsor
Very easy way to find out...
Get yourself an OBD reader  £14 using discount code
Or another Obd reader  at £15 using discount code
Then you'll know whats causing it and can easily reset it with the reader.
  • Sponsor
Might be fuse 15 in the cabin.
I don't have fuses in cabin do I ?? I fort they were all under the hood
Where would you say to get a obd reader from
  • Sponsor
Do you have the Owner's Handbook? Should be some info in there.
Well u was right with the blown fuse number 15 . So would that make the car run funny ? I don't have a spare fuse to try it
  • Sponsor
As I say, easy to find out, put a new fuse in when you can get one, and see what happens.  Let me see if I can identify one that won't matter if you borrow it; gimme two minutes.
Damm if this works I'll be so happy . It's my first car so not the best with it yet but getting better with this forum :)
  • Sponsor
Have you got a 5 Amp one n position 18? That's for a "Parking aid control unit" which sounds like something you could do without for a bit. I know the one you need is 7.5A, but I bet a 5 amp fuse will last long enough to prove a point (or not).
No I don't have 1 in position 18
  • Sponsor
Shame you're not nearer, I've got dozens of spare fuses!
Yeah is a shame I could do with advice . I'm in essex , Colchester
Unless it was a sarcastic reply, try clicking the links in the post!
Streetwize obd readers from Carparts4less, also available from Eurocarparts, ebay, etc.
