Lane assist with high beam components
I tried this afternoon to code the lane assist function with obd11. Managed a few smaller jobs so far but this one got stuck on getting into control unit A5. It doesn't appear in the list to start with so I added it but throws an error when trying to access it.  I found a thread with similar issue on an Audi but they did have the required components. I have high beam assist and the associated camera (unit A5) and thought that would be enough. Am I wrong? Code I am using it below. Taken from obd11 forums where other Octavia owners have reported success.
lane assist
  • Select Control unit 17 (Dashboard)
    Control unit Long Coding
    Bye 4
    Bit 6 Activate
    Bye 11
    Bit 1 Activate
    Select Control unit A5 (front / advance camera)
    Bye 0
    Bit 0 Activate
    Security access
    Access Code 20103
    Adaptation
    Channel - Seçim HCA_On_State
    Put emphasis on menu
    Channel - Seçim HCA_Warning_intensity
    Channel - Seçim BAP_Personalisierung
    Put emphasis on not activated
    Select the time of engagement
    Set adjustment via menu - emphasis on late
    Select Personalization spurt holding an assistant to a terminal 15 - channel
    Set value to last setting
    Select Control unit 44 (power steering)
    Bye 0
    Bit 0 Aktif
    Select Control unit 5F (Informationselektronik)
    Adaptation
    (49) function -Vehicle list BAP LDW_HCA_0x19
    Activate
    (21) vehicle menu operation-menu_display_Lane_Departure_Warning
    Activate
    (23) vehicle menu Bedienung_menu_display_Lane_Departure_Warning_over_threshold_high – channel
    Activate
If you only have high beam assist, you probably have a lowline camera at address 20. This cannot support lane assist or traffic sign assist.
Lane assist requires a highline camera at address A5. If your car had traffic sign assist/recognition from factory, you should have an A5 camera.
A picture of the camera from outside the car will confirm which is fitted:
- If it's built into the rear view mirror mount, it'll be a lowline
- If there is a blacked out section with a triangular cutout, it'll be a highline
thanks @langers2k I'll nip out later and take a look.  From memory it is built into the mirror mount so probably a lowline.
Hi, sorry to but into this thread. I have just taken delivery of a new VRS and tried to activate the high beam assist but OBD11 came back with 'not supported'. I have lane assist and beam controls etc; no problem activating on my outgoing VRS. Thoughts anyone or does someone have the long coding for the MY19.
