Alternator replacement issue with 1.9 TDI 66kW AGR..
Hey guys,
I have mk1 1.9 TDI AGR and the steering fluid pump is on top and the AC compressor on the bottom. The alternator that I need to replace is between them... Today I've tried to move away the AC compressor, but after 2 long bolts that I removed, it doesn't move a bit.. I can't see third bolt or something holding it, Does somebody has a workshop manual or removed the compressor on this concrete engine ?  I would greatly appreciate a bit of help. :blush:
Thank you! It seems, I have removed the right bolts but the compressor is just stuck.. Will smack it with the rubber hammer tomorrow and will see..
