Number Plate Fitting - rear access.
Anyone got their plates screwed on instead of stuck? If you did it yourself, was it easy to gain access to put the nuts on the plastic screws?
Edited by ChipUK
Most of screwed on numberplates that I have seen and/or owned have used self tapping screws.
They screw into a plastic insert, no nuts needed.
Why would you choose to screw them on rather than stick them on though?
I like to wash behind mine every couple of months
Got cherished plate. Can they be screwed anywhere then or is the plastic plate in a certain position?
No the inserts are in a set place.
Cheers Gizmo
