Does normal halogen headlight fit in place of original xenon?
So originally my octi rs has xenon headlights, but the right side broke. Can i use halogen headlight,(marked h1+h7), and use the bulbs+ ballast from the broken xenon one?
So basically i just need an empty headlight shell, is there a diff between the two? Or just the bulbs?
No, the projector is different between halogen and xenon versions so you'll need a xenon version I'm afraid.
Is it a pre-FL or FL MK2?
i was afraid too... its FL, 2011. cant find any used here around, and new costs 400€
FL halogen and xenon headlights are very different. Halogens can only move up/down whereas the xenon versions get an extra motor and control module for the AFS 'bending' lights.
Not entirely sure which side you want but there are a few on eBay which a LHD beam pattern at less than €400.
LHD driver side:
https://www.ebay.co.uk/itm/183598995860
https://www.ebay.co.uk/itm/223017697733
https://www.ebay.co.uk/itm/192253535034
LHD passenger side:
https://www.ebay.co.uk/itm/123163894079
Passenger side seems much rarer unfortunately :/
LHD driver side:
LHD passenger side:
thank you for your effort. its passenger side(EU)
Autoteile.de will be your best bet, they do sell on Ebay UK but often, not always, its a lot cheaper on their website.
Mmm, perhaps not, be sure to check whether they are LH or RH dipping, I have bought from them twice but it was for LHD beam pattern.
OTOH I think maybe the HID projector lamps have a flat beam pattern and will be good for either.
double check!
There is still a flick up on xenons so the OP will need to get the correct handedness :)
i see now guys the halogen one has just a "hole" for the beam. while the xenon is more like an eye, and can move. thanks guys!
