Day Lights
Can the LED (Headlights) diminish when the signaling goes? Like Audi ... or some skoda models. Mk3 models 2015. Vcds coding is available?
Edited by Costel
The LED DRL's can be coded with VCDS to do just that,
They can also be coded to alternate (white/amber/white/amber etc) however this is an MOT fail in the UK... so check the regulations in your country.
Not sure of your question.
Yes VCDS can code it, there is a map of VCDS owners in my signature plus several Facebook pages of VCDS owners.
I would like coding vcds for the daylight (when you signal to dim the daytime light or to quench)? I tried to find the forum but ... nothing
Or
Edited by Gizmo
Seems the OP is asking about the LED headlights not the DLR's if I've read his post correctly.
LED headlights on a 2015 Octavia?
I assumed there was a bit of a language barrier and that they did indeed mean the LED DRL, as per the video posted.
