Lowering
Hi
I have a 1.6 TDI Elegance, i'm wanting to lower my car be either 30mm or 40mm, my car is on 17" 7.5J rims with 205/40/17 tyres. I'm wondering whether the camber in the front and back will change out of spec and make unnecessary wear. Also, for my wheel choice already is it better to go for a 30mm drop or 40mm??
  • Sponsor
After changing any suspension part it's best practice to get the wheel alignment checked and reset. With 17's you should be fine with either 30 or 40mm.
Damian @ DPM Performance
Thank you, helped out a lot
Should be fine mines lowered 40mm and gets tracked and never noticed wear issues
