Warning Light Trio
I was sat in a traffic jam yesterday when on popped the Low Tire Pressure, ABS & Traction Control lights, they stayed on for about 20-30 seconds then went off, this happened twice then didn't happen again for the rest of the journey (about 40 mins) and haven't come on this morning.
I've read that this is something related to ABS sensor and may require new sensor or hub?
Is there anyone in the Stoke-on-Trent area with the kit to read the error code so i could possibly get a more specific diagnosis (not sure it it could be narrowed to to an exact corner?)
Car is '57 VRS Diesel
@Spoonboy90 - It may not be an ABS fault. Low alternator output can cause this too (and also automatically turn off the stereo, heater fan).
@KenONeill fans we're only on low but stayed on as did the radio but thanks for the info.
check your battery, low voltage throws up all sorts of weird lights / codes
Just left work and within a couple of mins all three lights came on and stayed on. Got to my destination, turned the car off turned it back on and now (without going anywhere) just the Abs light is on. I will check the battery when I get home.
