Windscreen wipers
How the hugamaflip are you meant to
A successfully wash the windscreen?
and
B change the wiper blades?
also to add a third can the doc oc take Bosch areofoil / twin wipers?
its currently got standard blades and I wouldn’t mind changing them
They won’t stand up as ‘normal ‘ car wipers do as the bonnet is in the way
Turn ignition on then off. Flick windscreen wipe function within 30 secs and watch the wipers park vertically in "service mode". Same procedure to exit " service mode ".
Edited by xman
So, you want to put your wipers into maintenance mode:
Ignition On
Ignition Off
Within 10 seconds, wiper control arm down
To return your wipers to the correct position:
Ignition On
Wiper control arm down
Maybe Stoofa more accurate, but you get the picture.....
To wash windscreen lift the wiper slightly or put into maintenance mode - they don't lift and stay as most other cars do.
As above. I'm well aware of the potential to cause damage, and just lifted the blades slightly off the screen yesterday.  Just a bit quicker than getting the keys out with wet hands.
