Dave
Is it possible to run a new drainage pipe for sunroof drainage on a MK1 Skoda Estate ?
It’s a lot of work but if you can get the part it’s possible.
You'd have to drop the headlining pillar trims and boot trims. Probably a lot more too.
Thanks  ( sounds like I need a new car! )   I have had the trim off behind the Bonnet pull but the hole revealed there is too small and I suspect the down pipe is clipped i
