HHC on 11 octavia combi fl?
in vcds how can i able hhc?(hill hold control)
can i even enable it? or only in o3?
pls instructions
It depends what ABS module you have.
Can you post an autoscan from VCDS?
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
   Component: ESP MK60EC1   H31 0121
   Revision: 00H31001
   Coding: 113B201C092500FA880F04EA90220051340000
   Shop #: WSC 73430 790 00066
   VCID: 7BF541EDFAE5679280-802E
1 Fault Found:
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 49
                    Reset counter: 85
                    Mileage: 123585 km
                    Time Indication: 0
                    Date: 2015.11.01
                    Time: 00:02:33
             Freeze Frame:
                    Count: 3
                    Count: 0
                    Count: 20992
                    Count: 397
                    Count: 43264
                    Count: 1
                    Count: 1278
                    Count: 0
Yup, that supports HHC.
Use the lcode helper to find the right bit and enable it. Can't remember which one it is off the top of my head :)
i  found the lcode where i can tick in the HHC. but thats it? dont i need to do something in adaptation?
Pretty sure that's all you need to do.
If it does need any basic settings doing, you should get an error code to give you a clue.
thanks, appreciate your help!
