Remote Fob Problem
I've had the car since October and the remote fob has always been a bit intermittant often needing a few presses for the car to respond.
I changed the battery but it made no difference.
I have done the re-sync procedure a couple times when it didn't seem to work and it restored for a while.
On Sunday it stopped working completely, won't re-sync or anything.
Central locking still works fine with the key in the lock, and if I don't turn the ignition on within 15 seconds the alarm goes off as it should (sometimes immediately, but usually 15 secs), and the car starts so obviously central locking, alarm and immobiliser are all stlll working, just the remote isn't doing anything. I changed the battery again, the old one still has well over 3v though.
Last week I got VCDS to sort out an airbag issue (ended up being a broken wire in the door boot), so have had a look for codes relating to the key/remote.
There was an old code about key 2 having an intermittant fault (I only got 1 key with the car).
I had a locksmith check the key is transmitting and he says it is transmitting strongly.
Unable to find any current fault codes I started working through the measurement blocks on the convenience unit and on page 10 found the blocks for the remote. It says 0 remotes recognized.
So I looked up remote adaptation and gave that a try (set value 1, press test and then save and then hold unlock button for at least 1 second until something blinks), but it never blinks anything to confirm the key is accepted.
I have tried all sorts of combinations, test then hole the open button, test then save then OK then hold the button but it never gets to recognising the remote, and now when I check fault codes I get 01179 - incorrect key progromming, possible causes: remote control adpatation incomplete. Yep, that sounds exactly like the issue!
I must be missing something - anyone got any idea what?
Could it be a problem with the car antenna or wiring to it? I can't see a separate fuse for it and since central locking and alarm are working I'm guessing it won't be a fuse issue, more likely a broken wire. Anyone know where it is or how I can trace the wiring?
Jim
Can you post your VCDS autoscan?
Autoscan results:
(01314 wasn't there earlier, that is worrying!)
Friday,29,March,2019,14:05:54:11634
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4437.4
Data version: 20190114 DS296.0
www.Ross-Tech.com
VIN: Hidden   License Plate:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72 76
VIN: TMBGS21Z872074489   Mileage: 215360km-133818miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 021 LB    HW: 03G 906 021 AN
   Component: R4 1,9L EDC G000SG  9251
   Revision: --H06---    Serial number: SKZ7Z0F3885992
   Coding: 0000071
   Shop #: WSC 73430 790 00000
   VCID: 6A8DC0E5607D3E77209-803E
5 Faults Found:
005697 - Please check DTC Memory of A/C Controller
               P1641 - 000 -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 214168 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:31:47
             Freeze Frame:
                    RPM: 798 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.36 V
                    Bin. Bits: 00101000
                    Temperature: 40.5°C
                    (no units): 0.0
005658 - Glowplug for Cylinder 1 (Q10)
               P161A - 000 - Open Circuit
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 214231 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:37:29
             Freeze Frame:
                    RPM: 882 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.29 V
                    Bin. Bits: 00101100
                    Temperature: 9.0°C
                    Bin. Bits: 10110000
005659 - Glowplug for Cylinder 2 (Q11)
               P161B - 000 - Open Circuit
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 214231 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:37:29
             Freeze Frame:
                    RPM: 882 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.29 V
                    Bin. Bits: 00101100
                    Temperature: 9.0°C
                    Bin. Bits: 10110000
005660 - Glowplug for Cylinder 3 (Q12)
               P161C - 000 - Open Circuit
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 214231 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:37:29
             Freeze Frame:
                    RPM: 882 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.29 V
                    Bin. Bits: 00101100
                    Temperature: 9.0°C
                    Bin. Bits: 10110000
005661 - Glowplug for Cylinder 4 (Q13)
               P161D - 000 - Open Circuit
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 214231 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:37:29
             Freeze Frame:
                    RPM: 882 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.29 V
                    Bin. Bits: 00101100
                    Temperature: 9.0°C
                    Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   VCID: 3FDB41B14B7F6BDFA77-806A
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1Z0 907 044 H
   Component: ClimatronicPQ35 084 0305
   Shop #: WSC 00000 000 00000
   VCID: 3B2335A15F6777FF8BF-806E
2 Faults Found:
01273 - Fresh Air Blower (V2)
            010 - Open or Short to Plus
00819 - High Pressure Sensor (G65)
            009 - Open or Short to Ground
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000004525578
   Coding: 418A0F030004140000110D000000000000087F075C
   Shop #: WSC 24064 210 13409
   VCID: 2B0305E1AF07E77F1BF-807E
   Subsystem 1 - Part No: 1Z2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00063477
   Shop #: WSC 24064
   Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
   Component: RLS     231006 014  1201
   Coding: 00471077
   Shop #: WSC 24064
1 Fault Found:
01314 - Engine Control Module
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 188
                    Mileage: 215361 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.65 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD0UCH3P
   Coding: 0020788
   VCID: 3D273BB9417379CFB5B-8068
   Subsystem 1 - Serial number: 6332MSME1320225C+
   Subsystem 2 - Serial number: 6342MSME1327306A4
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenksäulenmodul 036 0070
   Coding: 0000042
   VCID: 74B1DE9D32B9F8878A5-8020
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 942 D    HW: 1Z0 920 942 D
   Component: KOMBIINSTRUMENT VD1 1612
   Revision: V1612036    Serial number: SKZ7Z0F3885992
   Coding: 0007401
   Shop #: WSC 20033 576 03681
   VCID: 392F2FA9555B45EF993-806C
Address 19: CAN Gateway        Labels:. 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0020
   Revision:   H04 02    Serial number: 24080602001287
   Coding: 3D3F074807002303
   VCID: 2F3B11F19B1F9B5F377-807A
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 1612
Address 37: Navigation        Labels: 1T0-919-887.lbl
   Part No: 1Z0 919 887 B
   Component:      Navigation     0412
   Coding: 0000002
   VCID: 47CB595113AF231F1F7-8012
1 Fault Found:
02731 - CD Reading Error
            001 - Upper Limit Exceeded
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         005 0954
   Coding: 0000758
   VCID: 38292AAD6E515CE766D-806C
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V3.clb
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.069 H07 1806
   Shop #: WSC 20033 576 175713
   VCID: 353723997943A18F7DB-8060
Address 46: Central Conv.        Labels:. 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0203
   Revision: 00020000    Serial number: 00000000000000
   Coding: 81801A085283007F3F02050FC0085F96907C00
   VCID: 03538D416717CF3F83F-8056
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 73430
   Subsystem 6 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Subsystem 7 - Component:       NGS n.mounted
1 Fault Found:
01179 - Incorrect Key Programming
            000 -  -
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 149
                    Mileage: 215368 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:13:04
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Component: Tuer-SG         005 0944
   Coding: 0000758
1 Fault Found:
00121 - Outside Warning Light/Door exit Light Passenger Side
            012 - Electrical Fault in Circuit
Address 56: Radio        Labels: 1T0-035-095.lbl
   Part No: 1T0 035 095
   Component:        Radio        0412
   Coding: 0000402
   VCID: 6B83C5E16F87277F5BF-803E
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         005 0907
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
   VCID: 372B2991634F539F6F7-8062
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
   Coding: 0000144
Address 76: Park Assist        Labels: 1Z0-919-283.lbl
   Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
   Component: Parkhilfe 4-Kan H04 0020
   Coding: 0000001
2 Faults Found:
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 147
                    Mileage: 215320 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 21:05:24
01549 - Supply Voltage for Parking-Aid Sensor
            007 - Short to Ground
             Freeze Frame:
                    Fault Status: 01100111
                    Fault Priority: 3
                    Fault Frequency: 76
                    Reset counter: 149
                    Mileage: 214168 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:33:02
End----------(Elapsed Time: 01:26, VBatt start/end: 12.3V/12.2V)-----------
If I remember correctly, the remote antenna on that generation is literally a small piece of wire connected to the control unit, I'm sure someone else will confirm.
I'd try clearing all learnt remotes and relearning the one you have. Should be adaption channel 000 and 001 as mentioned here: http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Comfort_System
If that doesn't work, it's possible the remote fob or CCM have been replaced at some point. Different versions can use different radio frequencies which can result in either intermittent or complete failures of the remote.
Might be worth ruling out interference issues. Does this behaviour happen everywhere or is it worse in some places than others? Are there any non-Skoda accessories installed in the car?
Another thought...
Is your car an Mk II or a Mk II Facelift? My Mk II Facelift has, from memory, two extra vertical elements in the rear screen heater that don't seem to make sense as part of the heating function and my previous Mk II didn't have. They're about the right length for a 430 MHz radio antenna. I wonder if these are the receive antenna for the fob. Does your rear screen heater work OK? It might be worth checking the wiring to it. Can someone confirm what these vertical elements are?
Edited by Papfox
The MK2 FL antenna is inside the BCM in the drivers foot well :-)
Thanks guys - I was away without phone or internet all weekend so just catching up.
VCDS said the convenience controller was seeing 0 keys registered, but I did try clearing the memory as well and that made no difference. I was using the Ross-tech wiki as a guide.
In terms of interference, it has always been a bit intermittant, but last Sunday it stopped working completely when I was in Nottingham and hasn't worked since. I have been home in the west of Scotland most of the time and in Northumberland at the weekend so pretty certain it is not an external interference limited to one location! Internally I have bluetooth speakerphone, TomTom, and my S9 when I am going for a longish journey, but none of those are plugged in or turned on for short journeys. As far as I am aware everything else is stock.
The fob has a skoda badge on it and looks pretty worn. It has clearly been opened up quite a few times so it is possible the board has been swapped at some point.
I'll have a look in the drivers footwell and see if I can identify the CCM and see if the antenna is still attached. Looking at the readout, it does not seem to have a serial number and one of the coding lines is also all 0's so it might time to find out how good the local(ish) indy Skoda specialist is.
  • 4 weeks later...
I have been busy and still haven't resolved this - where do I find the CCM? I had a look in the drivers footwell (behind panels) and didn't spot it.
I saw a video for a golf which was behind the glove box - when I remove my glove box I see the studs the golf one mounts to, but mine is not there! (bracket looks different for Octavia)
Is it on the drivers side and I am having selective blindness, or is it hiding somewhere else like the central console?
Found it. Behind glove box on the left side hiding behind metalwork.
Swapped it for a S/H one, coded it the same and still unable to register the key.
Assume key is the problem despite locksmith confirming it is transmitting strongly.
Does the little light in the fob light up every time you press it. (just quick presses of the boot button, or test out of range of the car)
I have had to re-solder the internals of my mates vauxhall zafira fob as the battery holder had come away from the pcb so it sometimes worked, sometimes didn't, until repaired.And it got worse and worse until it was repaired.
You wouldn't have noticed it without inspection tho.
My Octavia fob is very worn, but never missed a beat so far (fingers crossed).
Edited by Tilt
  • 4 weeks later...
OK still have this problem.
Have now tried a friends old key (same year) and had a garage take a look (I think they tried a Golf key from same year)  and the CCM is refusingto learn any keys.
SInce I had the same issue with the second hand CCM (which was from a Golf) I am wondering if the coding in my CCM had got corrupted (I coded the second hand one the same, but I kept its code just in case).
Does anyone have a 2006 (or early 2007) 1.9 TDI elegance estate that could check the long coding for me?
The module is 1K0 959 433 BT (as was the Golf one I tried)
The long code I read from my original one was 81801A085283007F3F02050FC0085F96907C00
I have an autoscan in front of me.
The CCM is part number 1K0 959 433 AK
The coding is 01D002007F2D8505485F861004CC
Which does not look remotely like what you have.
2006 1.9TDi Elegance Estate.
Edited by J.R.
Brilliant thanks, I'll give that a try tomorrow - a bit late to be setting the alarm off now!
It seems that code is too short and isn't accepted by the BT version of the CCM. 😪
Its your lookout but no way would I blindly recode something with a string of characters that look completely different to what my vehicle currently has, I could easily have made a typo.
I may have to change a Can gateway module on mine to stop the Chinese head unit discharging the battery, when I do I am going to look at my existing long coding, understand every chosen option and why and only change something if i am absolutely sure its the right thing to do, after copying the original code and only one thing at a time.
I may be off target, but is one not a BCM (body) and one a CCM (convenience) ???
Edited by Tilt
And still, does the little red light light up in the fob every time you press it ?????????????????????
I can't find complete documentation of all the options and I do have a spare module that accepts my original code so I figured the risk was minimal. Even if I screw one up I still have the other.
The AK and the BT are both listed as CCMs.
As for the light on the fob, I already covered that, yes it lights up brightly (I changed the battery twice to make sure), so does the key I borrowed and the one the garage tried. Timpson tested my key and confirmed it was transmitting strongly so I am pretty confident the key shouldn't be the problem. Strange that 2 modules exhibit the same problem with the original code.
The only thing I haven't tried is trying to learn a key with the code that
Was in the Golf module because I was concerned it might be configured to talk to different sub modules, I was hoping same year and spec Octavia would have the same sub modules, but it appears J.R.s has a different CCM as and different sub modules so it isn't quite as easy as I'd hoped.
I have now tried 2 secondhand CCMs plus my original and attempts have been made to code 3 different keys (mine, a friends, and a garage tried with a key they had) all of which seem to be transmitting fine but none of the CCMs detect them.
I'm back to my original thought that the antenna must be separate from the CCM and/or a wire is broken between the CCM module and the antenna or between the CCM and some other module. Any ideas?
As far as I can tell the remote for this age of car is all done by the CCM and not the BCM as on later cars, the fact that the CCM appears in VCDS and has the adaptation for the remote keys on it supports this.
A new complication is that I lost my only key over the weekend and have a locksmith coming to make me a couple of new ones (fingers crossed), I explained that there seems to be a problem synching remote fobs and he said that won't affect the coding to the immobiliser, but I guess only having aftermarket keys is going to make it even more difficult to nail the remote problem down now!
