Rear damper dust covers replacing
Morning All.
 Can any one tell me how you to get the rop damper rod nut undone. I am assuming you have to find a swan neck 16mm ring spanner that will fit inside the mounting bracket and then hold the rod top with an adjustable to stop it turning.
Yes, double offset ring spanner and an open ended or adjustable spanner on the flat on the threaded shaft.
Thanks. Thought so , just having a job finding a ring spanner that will fit in.
Fingers of steel and sharp teeth!
