Superb Twin Door problem
Hi Friends
Any one can help me with that problem.
I wan t open the hatchback options but the open normal tailgate....
Welcome.
You need to look at the thread on broken wires for the car as I presume that is the reason.
18 minutes ago, Danny 57 said:
Welcome.
How ican open hatchback by manual?
Have a look here
there is also a search facility to help you out as well:rolleyes:
2 hours ago, DEL80Y said:
Have a look here
Ichecked the wires is fine nothing is demage. :)
It can be the various microswitches
I chang new one but stel some problem
Edited by Superb2009@
You checked them inside the flexible rubber boot?
Some of the one's that break are within the bundle of wire and can be easily missed if you do not pull the wires apart.
Yes the inside near the rubber
Is some like new, and i touch all wires is nothing.
I have the same problem on my  2009 superb I checked all the wiring and they are fine. I don.t know where to look and what to change. need some help please.
The best way to check wiring integrity is to disconnect the multi-plug under the headlining, remove the lining of the boot door and use a continuity tester on each wire to check for damage. It's possible for the wire to be broken without any damage to the insulation.
