Installing a inline lift pump - wiring ?
Can anyone tell me how to wire in to the ignition circuit from the fuses box on my Octavia MK 1  , I realise that the lift pump should have a oil pressure switch added but I am not bothering as I run on veg oil so not a danger. The pump has to be near the fuel tank so I can earth it down there but need one long wire to the fuse box . The pump is rated 1.3 amps. Thanks for looking .
I didn't mean the fuse box ( that is inside )  , I want to connect the wire from the pump to a live wire under the bonnet that comes on with the ignition .
