TCS Error
Hi,
I have a 2011 Skoda Octavia Elegance 2D and about 6 months ago it started to indicate “Check Front Left Light” and “TCS Error” not at the same times, but at start up. I noted if I jump-started that, the problem receded for a period.
I fitted new ABS Sensors to the rear and new battery, but the problem persists. Last week I again jump-started as trial and problem sorted (probably a week or more).
I do not have real concern about this issue, but am kind of puzzled at what is going on? When I get the TCS Error, if switch on and off the ignition one or two times. I can get it started and this has worked to-date.
Regards
Rayh024
Do  you have the ability to read with VCDS in case it throws any more faults and explanation?
Thank you for your response.
No I do not have the ability to read with VCDS, but leave it with me and I will pursue trying to acquire same
Once again Thanking You.
Rayh151
  • 11 months later...
Well Ray, did you get to the bottom of this problem.
Thank you.
