Front assist
Hi
So my new fabia has front assist however I am unsure if its working.
Is it the front assist only works for automatic braking and judging the distance of cars for acc?
I thought that a function of the front assist is when you park the car and the front bumper gets close to a wall (or car) it will alert you just like it does for reversing.
I have done multiple front parking manovers since buying the car and it has never given any warning about proximity to the wall (or car) infront.
This will be a handy feature for me as its sometime hard to judge the space infront.
James
No, it's not a parking sensor. Unless you are trying to park at speeds in excess of 20mph anyway!
That's a shame as I sometimes have difficulty to judge the distance.
is there any tips or hacks I could use to help me judge the distance easier?
Yes, when you hit the object in front, Stop.
I think this method is called nudge parking.  😉
Put something taller than the bonnet in front of the car. Like a dustbin?
Then get in the car and look at its proximity to the front of your car for you to use as a guide.
Thanks AG Falco
Thanks AG Falco
I don't get an audio signal when forward parking but the screen shows proximity bars.
That doesn't sound right. Front Assist doesn't do parking sensor style stuff. @gumdrop, I'm presuming you have front sensors? Little circular things in the bumper? You might have got the volume turned too far down to hear it.
Ah! I have had a few problems, perhaps I had better drop it off at the dealers.
I think there are settings for the volume on parking assist in the infotainment/stereo? I only have rear sensors but I'm sure there were volume options. It's under car then the settings cog, worth taking a look
It's also worth pointing out that it doesn't beep until you're quite close at the front! At least, it doesn't with my Ibiza.
Where I park there is a tree infront of my space. The bits of tree that sort of sprout out the base of it (I don't have green fingers :D) almost always set off the front sensors, but they don't make a noise- it just pops up the graphic in the screen.
I was sitting in rush hour traffic in Truro, the car sensors were tweeting away like an aviary of parrots.
I thought that fore and aft sensors only engaged when in reverse gear but it does not seem to be the case.
Even a pictogram of tail gating cars appeared! I think the software needs debugging it seems quite primitive.
