Blocked Screen Jets
Hi All,
My screen jets are partially blocked and only spray a small are of the screen, any ideas how I unblock them??
Regards
Tony
Pop them out (2 second job) and put them in some boiling water.
Then flush your washer fluid out and replace for screen wash that is suitable for fan jet washer (genuine VAG stuff is good)
Mine don't seem to be the fan type, is it an easy enough upgrade?
Great thank you, so its my screen wash causing the issue.
Yes really easy
MartiniB thanks for the info
Guys, need your help again. Took the fan sprayers off to clean them out and when refitting the lost the plastic clip which holds the connector to the spray module, don't suppose some has a spare they can let me have or the part number for a replacement?
Thanks as always.
Tony
