front wiper failure
Hi all
         driving along the wipers suddenly stopped about 30° above the horizontal.
         stopped the car and checked them. there was free movement in the wipers.
        wipers were moving ,thought it might be a mechanical failure.  got back home  and after sussing how           to remove the plastic scuttle, i tried to remove the wiper assembly. no chance!
         had to remove holder for ecu off bulkhead and remove a bracket.
         then there were several screws behind insulation. 1 nut which require a deep socket.
          the elusive screw was behind the aluminium covering on the bulkhead, so just made a small incision to            access the last screw.  removed wiper assembly and opened the motor gearbox. nylon gear wheel had               threads stripped, on a car  about a month out of warranty with 15k on the clock.
           is this a known issue ?
           thanks
Edited by 47269
