Mk3 Monty Transmission question
I’ve got the new 1.0tsi 110 6spd manual.
Does anyone know what transmission this has? MQ200 or MQ250? I’m looking at mapping mine but that pushes it to 240nm.
6spd Manual is the MQ250. Rated for 250NM.
The 5spd is the MQ200. Rated for 200NM.
As long as you're not doing clutch dumps and burnouts, you'd probably be fine upto about 25% over its rated "limit", it's sudden harsh surges (clutch dumps, burnouts etc), that are what damages it.
Cheers for that couldn’t find that info anywhere! Should be perfectly fine then at 240nm. Not planning on doing anything that would wear the clutch just a bit more power for the motorway ect as well as a few more mpg hopefully!
