DMF Chattering
When my car is cold there is a chattering type of noise which i am pretty sure is the flywheel, this sound goes when i press the clutch in.
The car also when cold tends to vibrate quite a bit where it would shake, stop shaking then start again... This also stops when the clutch is pressed in.
These problems disappear when the car warms up.
I have a Sachs SRE Clutch with a Sachs DMF which was needed since the car was remapped on a hybrid turbo but the clutch and flywheel was only put on the car in 2016 and iv only done just under 14K miles since then
which is why i thought it was odd that the DMF is showing signs that its starting to fail already?
I dont really know much about clutches but should i get the flywheel replaced as soon as possible or should i just leave it till it gets even worse, or will it to damage to the clutch aswell?
And also an estimate how many hours of labour i could be looking at paying for a flywheel to be changed?
Thanks.
Edited by B_vRS
The noisy DMF will not damage the clutch so your issue is not urgent, you probably have too much torque available from that hybrid for comfort and I suspect you've been abusing it and have dramatically shortened the life of the DMF.
Ce la vie.
