Window chrome trim adrift
Wife's car had this today, nearside rear top chrome trim dislodged by opening the passenger front door. Not enough clearance between both trims, one forces the other off.
Car is out of warranty but as this is a know issue I'm hoping Skoda will sort it out.
AmI right in thinking it is recall 64e3?
Yes it is. This may be of help:
Had mine replaced last September, after a couple of days of warm weather they are coming off again!
Well Skoda did a goodwill, re gluing the trim back on. Not dealing with the clearance issue and a bit of a crap job, will black sealant visible on the trim. Would have done a neater job myself.
I had my off-side passenger door trim replaced under warranty a year ago. It is just starting to pop up again, but it's minor right now. Will probably stop when it gets cold again, but I'll see about it in October when my last warranty service is performed.
Mine is doing it very regularly on the right passenger door whenever it is a bit warm or has had direct sun exposure.
I can also see something has been done before to try fix it. The edge of the drivers door seal has scuffs which looks like someone has tried to sand it down. Obviously didn't work.
Will have to get it sorted same time as service soon.
