Skoda octavia 1.9 tdi mk1 with a front and back oil leak
Hi i have an oil leak on my 1.9 tdi engine its wet with oil at the front and high up behind the engine i think it could be the rocker cover gasket are these prone to leaking?
Which 1.9?
1.9tdi pd 100bhp axr engine
Usually the cam cover or the oil filler neck.
@Joe41 - Well, my first call with a top cover oil leak is always to check that the bolts aren't loose. Don't try to fix the leak by over-torquing them though; That just crushes the gasket and possibly breaks the bolt(s).
Ok will try that first an order a new gasket its cheap so harm done is there a torque setting for the bolts on the rocker cover?
Edited by Joe41
