4 warning lights on
I have a Skoda Fabia 1.2 TDI greenline 2012 a few months back I had a problem with an indicator which turned out to be a burnt out wire. Now I have 4 warning lights on the dash ABS, TC, (Tracktion control )TP, (Tye pressure) yesterday my airbag light came on and my start-stop come up with an error. i have tried the button near the handbrake for the TP and the button for the TC near the middle air vents to reset but both of them do nothing  i  even bought 2 code readers and both of them say no error codes
thanks
You would need a proper diagnostic tool to read those codes, what you have purchased will show basic stuff only I assume.
What did you buy ?
@popoff10 - This might sound like an odd question, but are the battery and alternator good? I've had large numbers of warning lights at once when the alternator failed (car still under warranty).
Manually check all tyre pressures anyway and inspect tyre sidewalls, inside and out, for nails, bulges, etc. A free, small time task, that often gets overlooked as faults!
