Replacement turbo tsi engine
Hello I have a 2012 vrs facelift petrol with CCZA engine. unfortunately in a dumb move I topped up with the wrong grade oil and since then its been drinking oil at a frightening rate. Ive had a mechanic check it and he found compression was fine but the intercooler piping awash with oil. i'm guessing it ruined the seals in the turbo. I have the option of a 2010 vw eos turbo, engine code is also CCZ but the actual turbo number is in an impossible place to check to compare. Can anyone on here tell me if they are the same part? Thanks
