Parking sensors
Well - now I'm used to having the front left parking sensor failing every 10 months or so... but today when I hooked VCDS, instead of finding a single error for that particular sensor.. I found 4.
The usually failing sensor says it's shorted to plus and the other 3 on the line say are not responsive...
I checked all plugs, they seem clean - I swapped left sensor with right, and the short to plus error moved with it as well, still the other 3 were also throwing a not responding error...
Is this normal...? Should I consider replacing the controller?
