How to disable the equalizer factory in swing radio 2018 (Vcds)
Hi all After buying a Skoda Rapid 2018 I noticed an audio problem of the swing radio, I thought at first that it was a speaker problem, but after taking a look at the response curves of the car stereo, it is a real disaster !! :
Font :  Peak 60 hz
            Important loss 250-500hz
            peak 1000hz
            hole in   4000hz
Rear : Pic 60hz
           Peak 1000hz
           high level 4000-16000 hz
The problem has already been reported by Pixitrabi:
How  Skoda has not planned to deactivate this disaster in the car radio menu for a simple flat curve ??
i have never see this !
My question is how i can turn off the factory equalizer with viagcom to disable this disaster with vcds? which cable to use?
It is possible that Skoda have reduced the levels of certain frequencies that would cause vibration in the car?
I'm surprised that there's a peak at 60hz
Edited by Delberthot
perhaps, but it should be to disable this to return to a standard linear curve ?
Edited by hall
