Cruise Control
Hi All,
Just new to the forum and Skoda.
Just got my car a week ago and about to do a long distance drive with it.
Tried out the cruise control a couple of times but nothing seems to happen.
No indicators on the dash that its on and its not maintaining the speed.
Any suggestions? Could it just be as simple as a fuse?
Yes it could be.
More likely the switch though. A live data check with diagnostics would confirm this.
Edited by Tech1e
Did you make sure the toggle switch on the top of the stalk was set to on rather than in the off position?
1 hour ago, Tech1e said:
Yes it could be.
Damn, fingers cross its an easy check / fix.
Yes the switch was "flipped" to on
I would think providing it hasn’t had an engine ECU software update recently it will be pretty simple.
A faulty brake light switch or clutch switch (if it is manual) can also cause it not to turn on.
I'll have a look into this thanks
Oh right ok. Lets hope its easy to find out.
  • 2 months later...
Hi All,
Sorry forgot to place an update here.
Had someone look at the airbag light.
He couldn't find the airbag unit in the beginning so did a full reset and it was cleared.
After this Cruise Controle and auto door lock started working without any issues.
