Fabia vrs brakes
Anyone able to help? My 2004 fabia vrs seems to have a big problem with the brakes. When the car is left overnight the brakes just dint work the morning after. Pedal straight to the floor and only after pumping the brakes to they seem the work. Ive ordered a new master cylinder for it but not sure if that will fix the problem.
Try bleeding the entire system and the ABS block.
Ill give it a try. Thankyou
Take note, you do need VCDS or a similar works-grade diagnostics system to bleed the ABS valve block properly.
