2008/9 2l 170 Superb Front Discs
Could someone confirm what discs are fitted to the front of my Superb,  some say 312mm, others say 288.   I have measured them on the car and they are showing 320mm,  could this extra size be down to corrosion on the edges of the discs.  Or should the be 312mm?   Any info would be much appreciated.
Fronts on the 170 are usually 312x25. 320 is not a valid size for the Superb at all.
Four front disc sizes are:                                                             Rears Are:
77kW 1.9 PD -                       288mm  x 25mm                           260mm x 12mm
92 kW 1.4 TFSi
77kW 1.9PD Greenline  -    312mm x 25mm                            260mm x 12mm
118 kW 1.8 TFSi
103 kW  2.0 PD
125 kW  2.0 CRD -                312mm x 25mm                           286mm x 12mm
191 kW 3.6 FSi -                    345mm x 30mm                           310mm x 22mm
Could it have been fitted with aftermarket discs?
Edited by 3T51704x4
typo
Hi, thanks for info.  But in the email notification you state that 125kw has 320mm discs,  then when I go to Briskoda site it says 125kw has 312mm.  Now totally confused, had the car from new so not aftermarket discs.
312mm
Hi,  I'm now getting the impression that they must be 312mm and that the extra size of 320 that I measured must be due to the corroded edges of the discs.
VAG don’t do a 320 mm disc.
The correct dimension is 312mm not 320mm. I corrected the typo error 18 hours ago when re-reading the post.
Edited by 3T51704x4
Check the codes on the sticker in the boot, you'll need that for pad type as well.
Annoyingly the boot sticker doesn't have the PR code for the front brakes.
What’s the reg? will look it up for you tomorrow.
Ah, that's I teresting,  I thought it was just mine which had that missing.
And you are correct it is/was  annoying!
Edited by Gdcobra
That is down to the PDi bod, two data stickers come with the service book, one is fitted to the book and the other is supposed to be stuck in the boot. Some people have no idea what it is for or how important it is.
They will not reprint them either. Or the car has had some work done on the rear after a bump.
I think they mean the data sticker is there, just the PR codes for the front brakes isn't on there. Seen this a few times with really sparely detail PR stickers. All the build info is still on ELSA though.
Looking for 1LJ from the BEV family V= Vorn Front. Or 1KJ from BEH family H = Hinton Behind
Edited by 3T51704x4
Must read the posts properly.
