Mk1 Octavia vrs passenger side drive shaft remove
Hi all im planning on changing my driveshaft on friday my self just wondering whats the best way to remove it. Im doing this on my driveway if theres a link to show how to do it that would be great as cant find nothing on google. Thanks
- Remove centre cap from alloy wheel
- Undo 30 mm driveshaft nut
- Jack car up and secure on axle stands
- Remove wheel
- Remove driveshaft nut
- Remove inner flange bolts
- Remove bottom ball joint bolts
- Rotate hub clear
- Remove driveshaft
To install reverse, remember to torque driveshaft nut up correctly.
My only issue is i havent for a torque wrench
Then get one or gets someone to do it who has the right equipment.
Do you have a 30mm 12pt socket and spline sockets?
https://www.amazon.co.uk/Draper-30357-Square-Drive-22-1-154-9lb-ft/dp/B0001K9S52/ref=asc_df_B0001K9S52/?tag=googshopuk-21&linkCode=df0&hvadid=226606326869&hvpos=1o1&hvnetw=g&hvrand=17920650258175520787&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9044908&hvtargid=pla-421739989189&th=1
Well worth having one for jobs like this and doing up wheel nuts. I have a 3/8" drive one too which is good for lower torque things like spark plugs.
